Are the forks the same on these two bikes so that they can be interchanged?
2010 YZ125 2007 YZ250 Fork Interchange?
Started by
JMcClendon132
, Feb 28 2012 02:35 PM
3 replies to this topic
Posted 29 February 2012 - 02:14 PM
No, front brake caliper was changed in 08. You need to import the caliper with it and then it will work.
Posted 29 February 2012 - 02:32 PM
What's not been mentioned is that the correct master cylinder needs to be used with the caliper if you want it to stop anything. I've been told by a source reliable enough to raise doubts that the older caliper can be adapted by one means or other. Not clear on how that works, if in fact it does.
