Just bought this 350 and need to catch it up to ride-able.
Some issues:
1. Anyone know what the fork oil capacity/type is, and can I just drain and add, or do I need to tear it apart?
2. Swingarm-mounted chain guide is missing, and the OEM part not available--is there a source? Haven't been able to locate any used ones, either.
3. Any suggestions on the "correct" manual(s) to purchase?
1985 XR350 specs 'n' techs
Started by
bstrue
, Feb 23 2012 09:36 AM
7 replies to this topic
Posted 24 February 2012 - 06:51 AM
Wow--thanks!
XRay250, that'll get me riding sooner, and that's the point. Thanks for scanning the page.
Mindblower--I found the chain guides on XRs only, but they fit '83 and '84 models and not the '85s. Seems odd to me I can't find a replacement for the '85 model; but maybe I missed the obvious, somewhere...
Posted 24 February 2012 - 10:17 AM
bstrue, on 24 February 2012 - 06:51 AM, said:
Wow--thanks!
That's where I got mine. Call them, maybe they've got one lying around. If not, I'm thinking hard about putting an XRL swingarm on my 85 for the 18" wheel, disk brake and updated look. If so I'll have mine to get rid of. The 350 uses the 3 bolt mount, the L a 2 bolt. New parts are getting harder to find, and there's more of everything for the 83-84 bikes for some reason. Lots of it will work though. I have the XR's Only exhaust (only 83-84 available of course) and it works just fine with the upper mount being 3 or 4" off. Same as using CRF exhausts on these bikes. I'm using a Two Brothers carbon fiber exhaust for a CRF450. You can see the simple braket (steel strip,2 bolts/nuts) to attach the upper mount.
Here's the 1 I have.
Posted 24 February 2012 - 10:34 AM
Ah, good. I don't mind adaptations, but it REALLY helps when someone's already done them and made it work. I will call XRs Only about the chain guide. And yes, if you switch out swing-arms, let me know--I'd happily pay you for parts and shipping.
Seriously nice, well-kept XR you have.
Posted 01 March 2012 - 02:37 PM
Update: Mindblower's suggestion to call XRs Only, worked. You can purchase a swing-arm mounted chain guide for 1985 XR350Rs. The part number is XRCG-11-r or b or s. The r, b, and s choices are for red, black, or silver anodized. Woohoo!
