Opinion needed on damaged crank
15 replies to this topic
  • blackie107
Posted 22 February 2012 - 05:14 PM
A friend called me and said he used a 3 prong puller to pull the flywheel on his 05 450. I did not see it but he said the center of the crank pushed in about 3mm. I told him he made junk out of it. Was I correct in telling him that?  I'm assuming the insert that got pushed in is part of the seal for oil flow and now the big end won't get proper oil pressure.  Need some input. Thanks.
  • mrmoto35
Posted 22 February 2012 - 05:23 PM
Yes unfortunatrely thats what happens when you don't put the protecter cap on when pulling the flywheel. If there is a fix I have not heard of it. Be a nice friend and get him some tissue and a service manual.
Edited by mrmoto35, 22 February 2012 - 05:23 PM.
  • frankdecrosser
Posted 23 February 2012 - 11:48 AM
I once did more or less similar with a OEM Honda flywheel puller because a stupid dealer forgot to sell me the end cap wich you're supposed to put on cranck first.
That insert or whatever it is was also pushed in but i didn't replace anything. Orifice was still open and not damaged.
Traded bike in not too long afterwards but didn't have problems with it in that time and never heard anything back about it.
Post a pic so i can see if it looks similar..
  • mrmoto35
Posted 23 February 2012 - 12:35 PM
Yes post a pic. Sounds like there is hope!
  • blackie107
Posted 23 February 2012 - 01:48 PM
Here is a pic he sent me.
http://s83.photobuck...imagejpeg_2.jpg
  • Shawn_Mc
Posted 23 February 2012 - 02:46 PM
The problem is with the end of the crank fitting properly into the seal in the case. Part 15 seals the case to the crank to feed it with oil. If that seal isn't sealing, you run the crank dry or under oiled. The seal description: OIL SEAL (10X21X5) 91204-KRN-671
Thats 10mm on the inside, 21 on the outside and 5mm deep. If the end of the crank is still only 10mm in diameter you could be ok, but you can see its mushroomed in the pic. If all you did was push that bushing down a little, it'd probably be ok. Pop the seal out of the case and see how it fits on the crank end. If you've gotta stretch it over, its toast.
  • blackie107
Posted 23 February 2012 - 04:26 PM
Probably toast. Thank you all!! Brian
  • frankdecrosser
Posted 24 February 2012 - 10:43 AM
That is severe damage, i'm afraid Shawn_MC is right
  • blackie107
Posted 24 February 2012 - 10:53 AM
He's going to replace it. Thanks.
  • bryce716
Posted 24 February 2012 - 05:30 PM
Dude that sucks!I know the feeling,I did the same thing to my 07 crf450.I pushed it in about 4mm and mushroomed crank because I forgot about the cap.I didn't mess around,I replaced the crank and main bearings with oem stuff.
  • kwoody51
Posted 25 February 2012 - 07:21 AM
How the F do you NOT see that you are doing that during the process?!
  • Shawn_Mc
Posted 25 February 2012 - 08:51 AM
because the end of the crank is recessed below the flywheel. With the puller on, you simply cant see it.
  • Ericyzf359
Posted 25 February 2012 - 05:15 PM
so how do you go about getting the fly wheel off without damaging that piece. Im in the process of rebuilding my crf450
  • mrmoto35
Posted 25 February 2012 - 05:42 PM
I just did mine a few weeks ago. Buy one of the following. Made exactly for the crf flywheel. The little cap in the picture screws over the end of the crank to protect it.
http://www.ebay.com/...=item1c242ac2b8
Edited by mrmoto35, 25 February 2012 - 06:04 PM.
  • GTXR
Posted 25 February 2012 - 06:03 PM
Proper crank puller!!
  • Ericyzf359
Posted 25 February 2012 - 06:41 PM
ok thanks for the help i wasnt sure if the shop i work at has that puller but now i have seen a picture of it im positive we have that puller
