juliend, on 20 February 2012 - 12:52 PM, said:
That's how I got it out of mine. Heated the case half up in the oven and it simply fell out.
Well now...if I didn't know you, I'd be looking askance..sidewise even...at that idea. It
FELL out?
Oh well....
I went with plan 'Plan B'.
After three hours of chiseling bits of it out..sharpening my chisels over and over...straightening them out 'cuz they eventually bent (over and over)..fashioning a pointed wedge out of a scribe tool, cutting the other end off so I had something to hammer on..I finally missed. All it takes is one! Frankly, I'm surprised it took me three hours!! ..to finally miss, I mean.
So, now I have a hole in the cover, and I can proceed to 'Plan C'.
I had considered drilling a couple of holes in the cover so I could get to the bearing shell from behind. Having no reason to any longer wonder to what extent the cover strength would be compromised ('cuz I just put a hole in with a chisel), I drilled the hole..had the shell out in less than a minute.
This balderdash of heating up the case and that bearing falling right out.....Puhleeeze!! Consider the fun and excitement of THAT process..vs: three hours of banging AND getting to mix up a batch of JB Weld!
(I did put a torch to it, too before the hole process became a factor. Twice, actually. Uh...nothing fell out.)
Thanks for the input! I appreciate it!
