2012 250 SX
53 replies to this topic
  • Jwells221
Posted 18 February 2012 - 01:51 PM
I just got home from riding the new toy and was very impressed with how well this bike handles. I think this is the best over all bike I've had. It doesn't quite have the power my 01 cr250r had but I feel the power it does have is more usable. the only issue you I have with it is it wont stay running without any throttle? could the jetting be off?
  • jeffro667
Posted 18 February 2012 - 02:06 PM
Did you forget to remove the pipe plug? It shoud have 7-8 more hp than an 01 CR.
  • rmzpegger
Posted 18 February 2012 - 02:15 PM
Mine was jetted rich for my altitude. Dropped down to a 40 from 42 on the pilot. You should have received some extra jets and some PV springs in addition to a tool kit with your purchase. If not I would ask the dealer what happened to it?
Mine didn't idle either because for whatever reason the factory had the idle backed almost all the way out. It took about 5 turns before she would even idle for 5 or 10 seconds! The next adjustment will be the air screw and things should dialed in.
  • rmzpegger
Posted 18 February 2012 - 02:16 PM
Roger that! 50hp stock and I know it's there on mine!
  • hardhitwarrior
Posted 18 February 2012 - 02:30 PM
plug on a pipe? show me a pic?
  • Jwells221
Posted 18 February 2012 - 03:27 PM
My cr just seemed faster maybe because it was my first 250. but what plug are you talking about?  I didn't see nothing about that in the manual.
  • jeffro667
Posted 18 February 2012 - 03:57 PM
I was just kidding, I meant a wash plug that you put in your silencer for washing the bike.
These bikes are very tuneable, what power valve spring do you have in, how much preload on the spring, and which ignition curve. I rode a buddies 11, which is pretty much the same engine wise, his was set up fairly mellow, but it was still very strong for a 250.
  • Jwells221
Posted 18 February 2012 - 04:05 PM
Haha that's what I thought but this is my first ktm so i was unsure. I have the yellow spring in stock preload  on it. And it's on the the performance curve.
Edited by Jwells221, 18 February 2012 - 04:05 PM.
  • hardhitwarrior
Posted 18 February 2012 - 06:55 PM
go with the red spring. change your silencer. most KTM pipe are good to decent but the silencer is the one limiting the power.
  • originalmonk
Posted 18 February 2012 - 07:27 PM
Takes a few hours to break in!! Mine took the better part of 12-15hrs, it's an XC but it's a monster!
  • Jwells221
Posted 18 February 2012 - 07:57 PM
What's a good silencer to go with? I had a fmf shorty on my last bike I liked it but like I said before this is my first ktm and don't know what they respond best to
  • KX290F Pilot
Posted 18 February 2012 - 08:39 PM
With a 2 stroke you don't want a constant idle like a 4 stroke.  It should idle about long enough to put your goggles on.  The 2 stroke will have better snap down low if you tune the air screw and pilot so the bike can bareley idle and will die a few seconds after blipping the throttle.  My fully modified by MSR `97 KTM 250SX made 50hp.  The stock 2012 250SX is suppose to make 50hp stock and with some bolt on mods can reach 53hp I'm told.  Fast and fun bike.   Jetting should be close tune with air screw and pilot for crisp bottom end response.  Don't stress on the idle to much.
  • timmyp8823
Posted 18 February 2012 - 08:51 PM
A bike that won't idle is a PITA,and one that is jetted spot on will idle and pick up clean off idle.
  • originalmonk
Posted 18 February 2012 - 09:07 PM
Agreed! My 250xc idles perfect and runs super clean off the bottom. I did have to turn up the idle when I installed my Rekluse though.
  • jeffro667
Posted 19 February 2012 - 04:50 AM
In my opinion, don't get a shorty, they give the intial hit to the power, but don't pull as long. FMF, Pro Circuit, or DEP, should all be an improvement over the stock silencer.
  • hardhitwarrior
Posted 19 February 2012 - 05:13 AM
get a EU pipe like DOMA or HGS. i would prefer DOMA for the better characteristics.
  • KX290F Pilot
Posted 19 February 2012 - 08:08 AM
I was assuming this guy does MX and not off road where you stop all day and restart.  Different senario.  I was shown by Factory KTM mechanic, before KTM's were cool, how to set the bikes up for moto.  Guess I have been out of the 2 smoker loop to long.  Still that 2012 KTM250SX is a nice bike.
  • timmyp8823
Posted 19 February 2012 - 10:42 AM
If you take the time to set the idle and AS in conjunction with each other there is no reason that a 2t shouldn't idle and run good at small throttle openings.
  • Jwells221
Posted 19 February 2012 - 12:08 PM
So how do I post a picture of my bike?
  • alex999
Posted 19 February 2012 - 01:33 PM
Hi
Did you read the Motocross Action Review ?
They mentioned that the 2012 jetting was lean. They include req jetting in link
Hers a link
Alex
http://www.motocross...-KING-8221.aspx
