Anyone had rubber plug come out and spew oil?
3 replies to this topic
  • InstantPCWR426
Posted October 08, 2003 - 07:50 AM
Hello fair wealth of thumper knowledge. I recently had my rubber plug pop out while riding in Michigan's upper-lower.
This plug is located where the manual decomp lever used to be on previous models. It promptly sprayed out a nice mist of oil on my rad and headpipe. I've got the replacement in, but am wondering if there's a bigger reason that it popped out besides riding down I-75 for 12 miles. Lay it on me, peeps! TIA <Matt>
  • WR_Jason
Posted October 08, 2003 - 09:25 AM
Check your crank case breather hose that goes down the front of the frame. Make sure its not closed, clogged or otherwise restricted by a zip tie or anyting. Other than that, make sure your not over full with oil. Check the oil like 5 minutes after running the motor for an accurate check.
  • jetdave
Posted October 08, 2003 - 10:05 AM
I blew out my cam cover seal after I pinched my vent hose. I was pinching the vent hose all the time and decide it was in a bad spot. Now I run it in front of my engine on top of skid plate. :) Seems to be working better there and looks better too.
  • Vibeguy
Posted October 08, 2003 - 10:07 AM
Ditto WR_Jason above,
I would also use a small amount of high temp (red) RTV during installation.
