What engines are the same?
2 replies to this topic
  • DrBeardface
Posted February 17, 2012 - 07:26 AM
What year WR450 engines are the same? From component part numbers it looks like it's split up between 03, 04-06, and 07-09 or something thereabouts. Can anybody shed some light on this for me? Thanks.
Posted February 17, 2012 - 08:21 AM
'03-'06 WR's are the same basic Gen1 WR/YZ450. A lot of changes were made in '04-'05, but they were all refinements of the same engine, and everything pretty much interchanges.
The '07-'11 WR is the Gen2 engine used in the '06-'09 YZ450's and the bikes had aluminum frames.
The new '12 model is the same Gen2 basic engine with an all new chassis and EFI.
  • BoiseBee
Posted February 17, 2012 - 05:47 PM
I've got the March issue of Transmoto magazine, and Yamaha's Peter Payne reports that "Contrary to initial response, the engine is considerably different than previous generations of WR-450F's". So this 2012 may indeed be a 3rd generation to the 5 valve motor. He specifically mentions new modified conrod, new bottom end dimensions, new piston assembly, modified crankcase to fit the 250 chassis, relocated oil drain plug, re-designed gear shift forks, modified intake manifold, etc. etc.
