02 426 sprockets fit on a 2010 yz 450?
7 replies to this topic
  • YZF MAD
Posted February 14, 2012 - 08:08 PM
title says it all thanks!!!
Posted February 14, 2012 - 08:42 PM
Yes.
  • YZF MAD
Posted February 14, 2012 - 11:55 PM
excellant.i had just put new chain and sprockets on 426.then i was givein the all go to upgrade by the ball and chain.now owner of yz450.LIFE IS GOOD!!!! :bonk: :lol: :smirk:
Posted February 15, 2012 - 07:07 AM
You probably won't want to use a 14 on the front of the '10, if that's what's on the 426. They come with a 13 because the internal gearing is higher
  • Yamiryder
Posted February 16, 2012 - 05:44 PM
Are the sprockets worn on the 2010 or do you just want to swap them because they're new on the 426?
  • YZF MAD
Posted February 17, 2012 - 10:43 PM
sprockets are good on 450.going to retire 426.have noticed levers fit as well as i have some shorty aftermarket on her so will do a bit of a changeover.
Posted February 18, 2012 - 08:01 AM
...have noticed levers fit as well ....
Hold on there, cowboy. The front brake lever is likely to be significantly different. It will appear to work, but can cause the front brake to lock down on you as it heats up. The 450 uses a different lever starting in '08:
http://www.thumperta...853#post5844853
  • YZF MAD
Posted February 19, 2012 - 09:44 PM
cheers!!!GREY.YEE---HAA...
  • Hot  38 replies
  • Hot  36 replies
  • Hot  47 replies
  • 5 replies
