Safety Wire on Throttle Cable
43 replies to this topic
  • Metalman62
Posted February 14, 2012 - 10:40 AM
I'm setting up my new 250XC and a friend mentioned it would be a good idea to safety wire the throttle cable to the carb body and to the "grip-pully-housing". He explained this was a common mod and would prevent a WOT situation if the cabe were to get hooked on a branch while blasting thru the woods.
Can anyone with experiance point me to a previous thread where this may have been discussed?
  • rpt50
Posted February 14, 2012 - 02:01 PM
Look on KTM talk for much discussion of this issue. Another option is the motion pro replacement cable with ends that can't pull out. A lot of guys seem to like it, but I'm not one of them. My cable appears to be of significantly lower quality than the OEM version, required a good bit a massaging with a file to fit, and I can't really find a satisfactory route. I currently have it routed like a Japanese bike (behind the number plate and down the left side of the frame), but it sticks up too high over the bars. If your CDI mounts on the left side up by the headstock, you are probably going to have the same problem I have if you go with the motion pro cable. If not, you my be able to use a Japanese style route. I am probably going to go back to the stocker and try the safety wire method myself. Please post any good options/solutions you find.
  • zilla
Posted February 14, 2012 - 03:40 PM
I do the safety wire thing.. I also run a SCOTTs stabilizer and have the cable tied off so it cannot snag on it either..
  • JPDad
Posted February 14, 2012 - 05:15 PM
Hmmm...I was planning on getting the 4 inch longer Motion Pro, it looks good in pics. Where did you have the problem with fitment, on the carb end? Many run a longer Honda CR250 cable and run it down the right side I believe. I liked the idea of the Motion Pro, but now you have me concerned. I have the stock set up safety wired but I need to replace the cable soon.
  • bendawg62
Posted February 14, 2012 - 06:02 PM
I installed the Motion Pro cable (pt # 10-3000) on my 08 300XCW. I ran it behind the number plate and down the right side of the frame ( the CDI is on the left ). It fit great and is threaded on both ends so that it can't pull out. I'm really happy with the quality and fit.
  • randysoo
Posted February 14, 2012 - 06:46 PM
There's a new motion pro cable out called the T-3 that is 4" longer and is secured to the ends that thread in, so the cable can't pull out. No safety wiring required.
  • rpt50
Posted February 15, 2012 - 06:20 AM
What I bought was the motion pro T3. It required filing on both ends, but the carb end "button" (whatever is is called) was way off. It was probably twice as long as the stocker, and a good bit bigger in diameter, and somewhat irregular in shape. The throttle end was just a little too large to fit my G2 throttle. Overall, the cable housing was thinner (and appears less durable), and the threaded "thumbwheel" that you use to adjust the free play is really out of round and loose, but it does work. I usually like motion pro products, but I am not impressed with this one. Maybe I just got a bad one.
I'm really interested in the right side route mentioned above. Where do you run the extra cable? My bike has the XC tank, and I just can't seem to find a route that does not leave a bunch of cable sticking way up above the bars.
Edited by rpt50, February 15, 2012 - 06:21 AM.
  • Metalman62
Posted February 15, 2012 - 07:02 AM
I'm gonna take a chance and order the Motion Pro cable. I'll post up the results in a few days.
  • supervokes
Posted February 15, 2012 - 07:38 AM
You can buy an OEM Honda CR250R cable as well ... Excellent quality (made in Japan) and various lengths to choose from.
I bought the Motion Pro cable and had fitment issues as well. Its now sitting in my garage unused.
There are 3 different lengths you can choose from based on year of bike.
1993-96 CR250R [color=#FF0000]cable[/color] = 2.8" longer than stock KTM Honda P/N 17910-MAC-670
1997-99 CR250R [color=#FF0000]cable[/color] = 4.3" longer than stock KTM Honda P/N 17910-KZ3-B00
2000 CR250R [color=#FF0000]cable[/color] = 4.9" longer than stock KTM Honda P/N 17910-KZ3-J20
Agree with the above statement that Motion Pro is "usually"good stuff .. their cables not so much. My opinion is buy the Honda OEM one.
Edited by supervokes, February 15, 2012 - 07:41 AM.
  • rpt50
Posted February 15, 2012 - 09:24 AM
Great info! So do you think if I wanted to use a japan-style route, I guess the 93-96 cable would be best????????
  • Silverslug
Posted February 15, 2012 - 11:40 AM
I purchased a Motion Pro cable for a 99 CR250 and had no fitment problems on my KTM, both ends fit perfect. I will not got back to the stock cable or routing, wide open throttle in tight woods is not good. This happened to me twice in a Harescramble and I was on edge the rest of the race, not fun!
Edited by Silverslug, February 15, 2012 - 11:42 AM.
  • Monk
Posted February 15, 2012 - 11:42 AM
Same here but I run a GPR unit.
  • gruberyz
Posted February 15, 2012 - 11:46 AM
I took a wire rope tie which looks like a tiny muffler clap conected it to my stabilizer post then took a small piece of flat metal and fit it to the clamp with throttle cable run through it the cable can slide up and down with the suspension but can't hook on the stabilizer like that bad time climbing out of a creek bed "ouch"
Edited by gruberyz, February 15, 2012 - 11:47 AM.
  • gmoss357
Posted February 15, 2012 - 12:26 PM
the 4.3" Honda cable is ideal for running the cable down the left side, behind the CDI. Gary jp4 has listed the various part #'s several times. The CDI helps secure it, then some safety wire at both ends pretty much seals the deal.
this has all been covered in length here many times before.
IMHO, I think the right side run is too tight and I just don't like it. I also don't like behind the bars, untidies the cockpit.
I also don't like that the new MP T3 won't fit behind the CDI, but I may be satisfied with running it along top of the CDI. Haven't had the need yet.
The Honda cable is cheap and nice quality.
Edited by gmoss, February 15, 2012 - 12:26 PM.
  • bendawg62
Posted February 15, 2012 - 01:31 PM
I really do think that you got the wrong cable or a bad one. I didnt have any of the issues that you describe. The routing was quite easy and I dont have any " extra cable " sticking out anywhere. I even have a headlight on the bike, so I had to route it around the back of the bulb housing. I have another Motion Pro cable for a friends bike. If i can figure out how to post pictures, i'll post up a pic of the cable to see if its the same as yours.
  • bendawg62
Posted February 15, 2012 - 01:44 PM
I cant add a picture, so google, Motion Pro 10-3000 , images. see if thats what you got.
  • supervokes
Posted February 15, 2012 - 05:37 PM
Either of the 2 longer ones would work,
PS ... I found this info a while back and copied it down ... dug up the info, but forgot who posted it a while back (just reposted the info from an email I copied to myself from an old post ,,, copy/paste). So credit is due to somebody else .. not me :-)
As per gmoss above .. sounds like "Gary jp4" should get the credit for this
Edited by supervokes, February 15, 2012 - 05:40 PM.
  • JPDad
Posted February 16, 2012 - 03:52 PM
In theory, the Motion Pro sounds perfect, just frustrating to hear about the inconsistent results. Some say great others not, is the product inconsistent in quality and fitment, or do we just have differing standards and opinions? The Honda cable sounds like the safer bet for me right now, but...for those getting the Motion Pro, please follow up and give us your thoughts after you install it.
Thx
  • Metalman62
Posted February 17, 2012 - 10:38 AM
Thx
Motion Pro on order . . . I'll follow up with the results in a few days.
  • rpt50
Posted February 20, 2012 - 08:31 AM
I'm going to give one of the honda cables a try. I will also post results.
