Trials Chain
11 replies to this topic
  • moto vita
Posted 13 February 2012 - 04:30 PM
i just noticed that DID makes a Trials chain (520ERS2). I've never seen it anwhere. Does anyone have experience with it or know where to get it in the USA?
  • chuck4788
Posted 13 February 2012 - 08:37 PM
Not that chain but I've given up on non ring chains for off road use, the new T and X ring chain don't have the friction of the traditional O ring chains and DID has a narrow ring chain for applications that were not designed for the wide conventional ring chains. I've been converting my off road bikes to DID 520VT2 chains, including my Monty, and I like the long life,  easy maintenance, and ability to run dry to reduce dirt collection. These chains can last several years and based on life cycle costs are much cheaper than conventional chains, also seldom need adjustment.  I lube with a dry film teflon spray lube.
Here is a good price:
http://www.oemcycle....oduct/900082587
Edited by chuck4788, 13 February 2012 - 08:40 PM.
  • laser17
Posted 14 February 2012 - 06:09 AM
No experience with it, but am very satisfied with the Renthal chains ive used. The upgrade from the IRIS is noticeable as you just never have to adjust the chain. I imagine the DID would be a similar experience.
  • moto vita
Posted 14 February 2012 - 06:25 AM
That is a very good chain. I use it on several of my bikes. It is heavier, wider  and has noticeably more drag than a proper Trials chain though.
  • Hurricane Harry
Posted 15 February 2012 - 08:42 AM
This stuff works good at keeping dirt off your chain too.
  • chuck4788
Posted 15 February 2012 - 09:38 PM
Really?  Tests have shown that after warmup the T and X ring chains have low drag like the non ring chains. I run low HP light weight bikes and I can't feel the difference between a non ring chain and the 520VT2 chain.
A 520ERT2 chains weighs 3lbs per 100 links
A 520VT2 chain weighs 3.28lbs per 100 links, about 4oz more. Put half a cup less gas in your tank and the bike will weigh the same and be more nimble because of the lower CG.
  • moto vita
Posted 16 February 2012 - 07:04 AM
I'd be interested to see those tests. On a TTR 230 switching to a lightweight non ring chain makes an immediately noticeable improvement in response. I've also used the narrow X ring chain to smooth the response of a Trials bike that was too snappy for my tastes.
My original post refers to the 520ERS chain which is lighter than either of the chains you've mentioned. Also there is a significant difference between rotating, unsprung weight and static weight on the frame.
Edited by moto vita, 16 February 2012 - 07:08 AM.
  • laser17
Posted 16 February 2012 - 09:20 AM
Check out the "chain " on this 65KG 4rt (scroll down page) http://www.teamcecot...ws/psoc11f2.htm
  • 762SPR
Posted 16 February 2012 - 12:51 PM
:smirk:
That thing... is... amazing :bonk:
  • mikedamratoski
Posted 16 February 2012 - 04:13 PM
that bike is sweet. It looked like in one picture the fork legs were turned around? I don't know about this chain theory that a friend told me. He said that by useing an oring chain that it developes a drag and in doing that it helps to smooth out the power? I think on a trials bike a good chian would be smoother and in turn make less drag making smoother sections.
  • laser17
Posted 17 February 2012 - 05:26 AM
I think the issue with O-Ring chains was that traditionally they were much bigger and heavier than the chains needed on a trials bike and definitely sucked out a fair amount of power. That extra mass is hard to spin up! The new O,D,Xring type chains are much smaller and lighter and why they are drawing more and more favorable feedback - especially for SSDT type riding. That said - I know guys who converted there 125's over to 420 chains to maximize snap. (punn intended... :smirk: ) Like just about anything in trials - the real answer is  - It depends!
Edited by laser17, 17 February 2012 - 07:47 AM.
  • chuck4788
Posted 17 February 2012 - 12:39 PM
At my skill level I have all of the snap that I need. :smirk:  Because I also do a lot of trail riding I installed a stiffer carb spring to make the throttle feel more like my trail bikes.
I ride in a lot of mud and water which is really hard on conventional chains so for me the switch to a light T ring chain provides a lot of maintenance and cost benefits. If a sponsor maintained my bikes then I'd go for the ERS chain.
