swaping in a YZ450 crank and piston to a yz426 engine case.
10 replies to this topic
  • hotdamnreg100
Posted February 12, 2012 - 02:55 PM
hello, my name name is reg. I just blew the crank in my yz426. Wanted to know if anyone knows if you can swap in a 450 crank and piston into the yz426 engine case. I want to know cause no one makes the 426 crankshaft other than yamaha and they are expensive. Thanks for the help.
  • 1987CR250R
Posted February 12, 2012 - 03:48 PM
Just remember, you get what you pay for in aftermarket cranks. What did you blow on it? Did you weld the rod to the pin? That should be rebuildable.
  • The Spanky
Posted February 12, 2012 - 03:59 PM
The stroke is different.
  • freewheelers
Posted February 13, 2012 - 06:57 AM
Your crank is rebuidable ... about $150.00 for the rod kit ... $50.00 labor to install the rod ... total $200.00
  • hotdamnreg100
Posted February 13, 2012 - 11:07 AM
The timing gear is messed up. Is the 450 piston pin bore closer to the the top of the piston to make up for the stroke. Or are to two engines completely different. Wondering If I can use the 450 crank and 450 piston in the 426 block and jug.
  • 1987CR250R
Posted February 14, 2012 - 12:15 AM
The timing gear is not pressed on the crank? You should be able to buy the timing gear if it is.
Posted February 14, 2012 - 07:56 AM
Nope. It's cut in place. One reason maintaining your timing chain is so important
  • 1987CR250R
Posted February 19, 2012 - 06:28 PM
How expensive is too expensive for the crank? You can buy it new for $297 through Service Honda. You can buy and replace the damaged crank half for $200 but you'll still need a pin, rod, and bearing which is another $100 and add $100 in labor on top to build it.
  • hotdamnreg100
Posted February 22, 2012 - 02:26 PM
The gear is part of the crank. It's pretty mangled.
  • hotdamnreg100
Posted February 22, 2012 - 02:27 PM
I'm in Canada and the cheapest I could find was 440 big ones.
  • 1987CR250R
Posted February 28, 2012 - 07:31 PM
www.servicehonda.com sells Yamaha parts at a substantial discount.
  • On January 15, 2017
  • Hot  47 replies
  • Hot  36 replies
  • 0 replies
  • Hot  50 replies
