I've been jetting my bike, trying to dial it in to my mods, terrain and weather. Last week I was at a 152 main, 48 pilot, stock needle and 2 turns out. So I got an adjustable needle (7 position NCVT) on the 4th position, same 48 pilot and 152 main. Bike ran the best it ever has w/ no bog off idle except there was a small sputter/gargle @ 1/4 when just putting along. So I knew it was running rich, so I changed it to the 5th position, 48 pilot, and added a 165 main. Installed those lastnight, started the bike, played w/ the fuel screw and idle for a min and thought it sounded ok. Got out to the woods today and I stalled the bike, alot. It was running fine, maybe a hair of bog, maybe just from the screw, but running good. But when I stalled or just stopped the bike, I couldn't get it started. It was a nightmare to start allday. I knew it was the idle and fuel screw, I just couldnt get them dialed out there for some reason. Bike was so hard to start. As I turned the screw in, it got better. I think I rode most of the day on 1 turn out w/ a good idle, but still not that perfect hum. I got home and played w/ it some more. Finally, 3/4 turns out, idle adjusted w/ it, the bike starts right up everytime w/ half a push of the button, runs and idles perfect, no bog, gargle, nothing!!
My question is, if the fuel screw is less than 1-1/2 turns, that means my pilot is to big right? Is it on to run it as is or do I need to try my 45 and 42 pilot jets so that I can get it to about 2 turns out? I forgot, is turning the screw in (lean) and out is (rich)? Is this why I had to adjust it so far in because I'm so rich on the pilot? I guess the needle fixed the lean condition and I should be able to go back to a normal 42 or 45 pilot @ 1-1/2 to 2 turns out.
