TIRES
5 replies to this topic
  • TORCH
Posted August 12, 2001 - 07:49 AM
Which tire combos have you
guys found to work best for
dry hardpack conditions?
im running the dunlop 756 front
and the 739 rear both @ 14 psi.
the rear seems to hookup pretty good
but the front end feels
a little bit loose.
anyone have any suggestions?
  • yzernie
Posted August 12, 2001 - 08:52 AM
The 756 is a intermediate to soft tire. If is really hard and dry, the bridgestone M23 works great.
For anything less that blue groove hardpack, I use the Dunlop 755 which is a great all around tire. It works well on the hard stuff and still works good in the softer stuff.
Ernie
  • motoman393
Posted August 12, 2001 - 11:36 AM
Dunlop 755 front and Bridgestone M78 (120/90) rear this combo works really well in the hard stuff and crosses over really well in the soft stuff as well! This is the only set up I run now!
Garrett
I get my kicks on a 426!
Motoman393's MX Site
  • motojunkie
Posted August 13, 2001 - 01:26 PM
I use Michelin MH2's front and rear with good results. Also, try reducing pressure in your tires a little. I was running 14 psi, dropped to 12-12.5, and noticed a big improvement.
  • elroyona426
Posted August 13, 2001 - 06:36 PM
I've been having good luck with the Maxxis Maxxcross HT...not only do they last quite awhile but they're pretty cheap
  • forloop
Posted August 14, 2001 - 05:08 AM
I want to second Motoman393 sugestion. I ran this setup on my KX250. It works very well. As soon as the Texas heat cools down I will be switching mine to this combo.
Rick
01 YZ426F #85 Vet C
Motocross
  • Hot  491 replies
