A few questions on my 06 wr 450
2 replies to this topic
  • Cpriest10
Posted February 12, 2012 - 07:07 AM
So yesterday I picked up an 06 wr 450 that's in pretty good shape with a few minor exceptions. Ok my first question is will the front number plate from a 06 yz 450 fit it?(it has no headlight now). And the second question it's leaking a little antifreeze out of the bottom, after doing a little research I think it's the water pump seal? How hard is that to fix, or how much would I have to pay to get it fixed? And also where could I get the parts to do that? Thanks in advance
  • Stealth13
Posted February 12, 2012 - 08:16 AM
My 06 leaked a bit out of the hose the first couple times I started it this year, and hasn't since. So make sure it keeps leaking before you pay to have it fixed
  • MANIAC998
Posted February 12, 2012 - 09:45 AM
Cpriest, I think your saying it's leaking out of the bottom of the water pump, at the weep hole, correct? If so, then yes, the water pump seal will have to be replaced. It's not all that difficult if you have the manual. Maniac
