Will a 2007 clutch cable work on a 2004 model?
6 replies to this topic
  • KGSloan
Posted 12 February 2012 - 06:27 AM
Hey guys,
I went to install an MSR Raptor EZ pull adjustable clutch perch and lever, because I'm a big wuss and want lighter pull. :bonk:
When I got the new perch on, I was not able to take enout slack out to get the clutch adjusted properly. The distance between where the cable cover sits and where the end ball attaches in the clutch lever is .5" shorter than factory, and I couldn't make up the difference. I messed up my factory cable in the process of trying too.
So I would like to get the t3 cable from motion pro, but they don't make one for the steel frame wr. Anyone know if the two cables are interchangeable?
Anyone know of a way to get rid of that .5" extra between the cable housing (where it inserts into the perch) and the end of the cable (where the cable end goes into the lever)
Any ideas or help are greatly appreciated.
THANKS!
-kit
  • GammaFunction
Posted 12 February 2012 - 03:33 PM
I had the same problem with my 03 when I installed a Works Connection perch. You need to use a YZ cable instead of the WR. The stock WR clutch cable has an allowance for the clutch switch that makes the cable longer.
  • KGSloan
Posted 13 February 2012 - 07:24 AM
thanks - that's exactly the info i needed. had no idea, but that makes sense. Ordering up a yz cable now :bonk:
  • GammaFunction
Posted 14 February 2012 - 06:29 PM
Be sure to post the results.
  • KGSloan
Posted 15 February 2012 - 08:58 AM
will do - cable shipped yesterday and hoping to ride saturday.....
  • GammaFunction
Posted 03 March 2012 - 04:34 AM
  • KGSloan
Posted 02 April 2012 - 12:23 PM
View PostGammaFunction, on 03 March 2012 - 04:34 AM, said:
sorry this has taken so long to respond to - the cable from motion pro was a pile of crap, went with a factory yz cable and all is well now
still would like it a little shorter than a yz on the length between inner and outter cable length - as that's the issue with the factory wr cable. the yz cable is just enough different to work
