well I screwed my hub and striped out a bunch of threads.... Can fix if i can get a bottoming tap from tool supply. anyone happen to no what size threads and pitch or anything like that, anything would help, i might be able to file the threads but its pretty tight in there.
rear hub retainer ring thread size?
Started by milesdeep, Feb 11 2012 09:26 AM
3 replies to this topic
Posted 11 February 2012 - 09:26 AM
Posted 20 February 2012 - 08:23 AM
I'e used a Dremel tool with a thin cutting disc to clean up the inside threads of the hub. I'd hate to think how much a tap that big costs.
Posted 20 February 2012 - 07:37 PM
dremal worked it was pretty easy. although I bought the tool to put a new retainer ring in but it was not the right size? I ended up grinding three tabs off . sloppy but worked. also priced the tap it was supper expensive. would of bought a hub off ebay instead, thank you for the help mctuner..
