Rear rotor Bolt replacements
4 replies to this topic
  • tek_01
Posted February 10, 2012 - 10:50 PM
Hi, long time since ive been here... havent done enough riding TBH but anyhow i needed to replace my rear rotor as the stock one bent somehow
Got the aftermarket one, but it comes with countersunk holes instead of the holes suited for the original hex head bolts (05 450f)
Im having a real hard time finding replacement bolts, even tho every aftermarket rotor comes with those crap holes so they must be out there
Stock are m6 x 16mm hex head flange grade 8
I can only find
Black countersunk allen head (standard grade)
Stainless steel countersunk allen head
Any help? need them before next weekend
I know its a no-no to mix stainless with alloys right? unless you use some sort of thread lube but on the bolts you are supposed to use loctite which i think would make the situation worse
Anyhow, any help appreciated
Edited by tek_01, February 10, 2012 - 10:55 PM.
  • niles
Posted February 11, 2012 - 03:14 PM
Check with moose racing.
  • stroker101
Posted February 12, 2012 - 06:35 AM
are you sure that the 2005 YZ has standard hex head bolts as OEM bolts? i beleive that all year makes use counter sunk bolts for securing the rear sprocket to the hub. i have never seen a Yamaha with what your describing.
if replacements bolts are needed, try Yamaha Parts for replacements or any aftermarket bike company
Edited by stroker101, February 12, 2012 - 06:36 AM.
  • tek_01
Posted February 12, 2012 - 03:14 PM
stroker, brake rotor bolts not sprocket :smirk:
Ended up sourcing some at a bike shop. bloody expensive $20 for 6 bolts but you gotta use the right ones aye!
  • stroker101
Posted February 12, 2012 - 06:01 PM
i'm a __________ LOL...
