Hey all, I've been readin post on here for awhile but I need some personalized help now!
I've got an '84 xl600 that I've been rebuilding, and it smokes like crazy when its running. Cold, warm, hot, still smokes.
My guess is that oil is burning, and i had a mechanic do a leak-down test, he said the valve seals needed to be replaced. So I replaced the seals, and lapped the valves, put it all back together and STILL SMOKE!
I have taken it back apart again, and when you look at the bottom of the head, that auto-decomp valve seems really wet? Is that a good (bad) sign that its leaking?
Also thought that the rings might be bad but the cylinder walls seem clean?
I will post some pics up after work, any and all help is appreciated!
Thanks!!
