I've used the screw driver and vice grips trick for adjusting my valves. Now I am in the middle of replacing the piston, do I need to buy/make the tool or can I still use the screw driver to release tension on the CCT when removing the cam?
Once I remove the cylinder, is it ok to remove the screw driver and let the CCT return to the normal position until it is time to bolt on the cylinder head and replace the cam? How will this impact the timing, if at all?
Appreciate the help, this timing stuff scares the heck out of me.
