Hello everyone, I'm currently riding a ttr 230 and am looking to rejet/uncork it. I ride pretty musch strictly mountains and that means occasionaly crossing rivers. I was wondering if pulling off the snorkel and drilling the airbox would lead to water getting into my air intake and cause problems. Also are there any other inherent dangers of rejetting?
Rejetting Dangers
Started by TTR230Nick, Feb 05 2012 08:53 PM
7 replies to this topic
Posted 05 February 2012 - 08:53 PM
Posted 06 February 2012 - 06:29 AM
Technically, that is called 'uncorking', which then requires re-jetting.
Only you can determine whether opening up the airbox will be an issue for the water crossings in your riding area. But it will make a noticeable improvement in how the bike runs and performs once it is all done.
You can be creative and limit points of entry of water to the airbox by using Gorilla tape, or creating your own larger snorkel to limit water entry.
On a TTR230, I would be more worried about the wiring harness, and the stator cover I think. They need to be water-proofed.
Posted 06 February 2012 - 02:43 PM
I don't cross water particularly often so that should be fine. How much more likely is it to get water in the intake once it is uncorked?
Posted 06 February 2012 - 03:04 PM
It's not. Unless you wash it and spray the hose under the seat, or ride in deep water (1') for more than several seconds, you should have no issues.
Posted 06 February 2012 - 04:16 PM
Posted 06 February 2012 - 05:42 PM
TTR230Nick, on 06 February 2012 - 04:16 PM, said:
I have crossed water thats about 2' but only a couple (literally like four times) that took my 3-4 seconds across but that's a rarity. ANd since you say it is a noticeable difference in power I'll seriously consider it. Thank you.
Buy a JD jet kit and follow the instructions.
Posted 09 February 2012 - 05:12 PM
Check the top of the air box after a ride to see how much water is getting there, then determine if you want to risk pulling the snorkel. I ride my XR in an area with lot of really big water puddles and it was obvious that lots of water was getting under the seat and on top of the air box so I left the snorkel in because the raised lip keeps water from running into the box and the duct inside the box shielded the element from direct splash..
