clapped_r6, on 05 February 2012 - 10:20 AM, said:
thanks for the replies. this is my first 2 stroke so i'm just wrapping my head around how to do everything!
Two strokes are big air compressors. As the piston goes up, it sucks in air/fuel through the carb and as it goes back down again, that mixture is forced up above the piston for combustion. The reeds are the only thing blocking the air/fuel mixture from going right back out the hole they came in on. Once the piston starts going back up again, it compresses the mixture and fires a spark to ignite it. As the piston goes back down, the remainder of the charged fuel/air goes out the exhaust port and the whole cycle happens again. Once you can get your head around how a 2 stroke works, the whole big air compressor theory, then you can diagnose them much easier. Unlike a 4 stroke, which the rings only have to a good seal on the compression stroke, on a 2 stroke, the rings work double time, both up and down to generate that "compression" which sucks in the air/fuel. So if things arn't perfect, the bloody thing just won't start. Higher the RPM, the more compression will get generated, which is why sometimes you can get it to start, you generate just enough pressure and once it gets started, it will run.
i'll get a compression gauge to get a baseline, then i figure i'll take it apart to see what is going on.
Yeppers, but with that many hours on the clock and NO piston/ring replacement, it needs one guaranteed!
what do you use to pull the top bearing? a specialized tool, or small socket?
1/2" socket extender. Fits the hole perfectly and I use a little rubber mallet to gently tap it out. The nice thing about using a socket extender is, you can pull the pin out and push the extender all the way through to hold the piston in place if need be. Putting the pin back in is actually more difficult then removing it. Usually I set it in the piston first, get in far enough, right before it peeks out from the inside hole where it grabs the rod and then put it in place.
In terms of pistons, Vertex is the
OEM manufacturer, so just buy one of those. They are sized (as I said above) so make sure you order the right one by first checking the size/number of the piston currently in the motor.
2 strokes are a blast to work on, lots of fun, very little can go wrong unlike a 4 stroke. So enjoy your time, ask more questions if needed and I find the parts look up to be very helpful in terms of remembering which part goes where!
