Exhaust Bridge
4 replies to this topic
  • packfill
Posted 04 February 2012 - 08:09 PM
Not sure if this is where to post this but...I have a 1998 RM125 that keeps losing the top end. I've read about relieving the exhaust bridge .002/.004, but haven't done it on any of these rebuilds. How do you do it? With a dremel and a cratex wheel? How do you check it? With a surface plate and an indicator?
Thanks...
  • Krannie
Posted 04 February 2012 - 08:30 PM
Post in Suzuki two stroke section
  • packfill
Posted 04 February 2012 - 09:16 PM
Already tried that. Kinda lookin' for someone that's done some engine work that could help me out before I put it back together just for it to seize up again cause the exhaust bridge is not relieved.
  • harryhandshake
Posted 05 February 2012 - 07:32 PM
all you need is a small straight edge to put through the cylinder from top to bottom across the bridge and you can see how much it needs grinded. dremel will work fine. make sense ? if it has steel sleeve you wont have a problem doing it now. on a plated jug you would want it relieved before the plating was applied. might check your service manual. sometimes they show how to do it. honda books usually do anyways
  • packfill
Posted 06 February 2012 - 02:09 PM
Thanks.
