Chain of events!
Chain came off and cracked the case, was able to continue and wasnt leaking too bad,
went through creek and was dropped in to creek. Switched the motor off instantly, Later after empting air box, wringing out air filter and draining carb started and was ridden almost back home and the rear wheel locked up pulled in cluch and continued to roll ( thankfully down hill )
Brought home washed, drained oil + replaced filter, re filled oil ( case still not fixed) completely cleaned carb and put back together and will not start!!! Checked spark and its all good! Why wont it start?????
Mate of mine suggested that there may be no compression and thats why it wont start? However before it locked up started and ran perfectly.
It turns over with both kick and electric start. but will not start can heap popping ( fuel build up?) But will not start.
Suggestions ??
Please Help!
