I know my 1996 XR600R has a slightly tweaked subframe, I just can't figure out which way it needs to go in order to be straight- the right or left side?
Tell tale sign my new/used bike has a prob.
Ok so if I look at the rear most portion of my subframe I can see one side is slightly higher than the other and one is skewed (less that vertical. as evidenced by the flat mounting portion of the rear tab that should be vertical). I can't figure out if one side is higher or one side is lower and which way it needs to go. Plus, anyone have ideas on how to get it bent back into shape?
And if I look down from the top...one of the ends looks like it sticks out further than the other. It's not the camera, one side is a tad bit longer than the other. Again, is it supposed to be like this? Hoping someone has their rear fender off and can look and compare, maybe post pics?
