Issue with Bark busters on throttle side
13 replies to this topic
  • coinless
Posted 03 February 2012 - 09:52 AM
Im installing my bark busters on the throttle side and the throttle assembly is smaller that the inside diameter of the handlebar. Do you drill it out? It is plastic.
  • ickfinger
Posted 03 February 2012 - 09:59 AM
one ez fix is to hit the end of the tube while its still on the bars with a hammer. it will cut the tube to the exact od of the bars
  • JimDettman
Posted 03 February 2012 - 10:57 AM
I took mine off and used a hacksaw to cut off enough of the throttle tube so that when installed, there was a 1/8" gap between the end of the throttle and the end of the bar. Doing that makes it impossible for it to hang up.
I got that advice here on TT. You would think dirt and stuff would get in there (I was doubtful), but after two years like that, I haven't had a problem and never had the throttle hang up.
Jim.
  • woods-rider
Posted 03 February 2012 - 10:58 AM
sawzall to the end of the tube
  • ickfinger
Posted 03 February 2012 - 01:16 PM
I forgot to mention after you whack the end off, smooth out edge with a file. hacksaw or sawzall will work, but you usually cut off more than necessary, leaving extra room for grip to bind and stick your throttle. It looks cleaner and you can use the entire grip, by only hollowing out the center
  • PANDJ RACING
Posted 03 February 2012 - 02:55 PM
Don't use a hammer, cut it off and file any burrs
  • Sampleinajar
Posted 08 February 2012 - 09:11 AM
This is good advice. I cut the end off of mine with a hack saw, and was really careful, but still ended up with the grip being too short - no way around it. carefully drill out the end to preserve as much of the throttle tube as possible, or purchase an aftermarket tube that has an open end.
  • SilvFx
Posted 08 February 2012 - 09:28 AM
ding....ding...ding....Sampleinajar hit the answer that works best for me. Look at the ODI lockon grips. They already have the open end....replacement throttle tube and no gluing for $19. I used for WR250F and YZ450F....no issues. Here is the link for CRF250X:
http://www.rockymoun.../2824/-/179570/
The other approach that I have had luck with is using a belt sander to sand off the end of the grip and the end of the throttle tube (esp with OEM Kawasaki grips where the rubber grip seems to be permanently mounted to the throttle tube.
Zeta Racing/DRC Hardware also makes open end grips and open end throttle tubes.
http://www.zeta-raci...ttle/index.html
http://www.drcproduc...1-04/index.html
Wheeling cycle supply carries Zeta Racing and DRC Hardware, has quick turnaround and cheap shipping.
http://www.wheelingc...com/index.shtml
  • Jakeblues
Posted 08 February 2012 - 09:44 AM
CUt off as little of the end as possible, to keep the full length of the grips and tube. Whacking the grips against the bar with a hammer works fine on the nonthrottle side, but will allow the grips to drag on the bar on the throttle side. Personally I use an exacto knife and cut into the center and work my way out to the inside diameter of the tube. Then just move the whole assermbly farther inboard on the bar to get clearance for the barkbuster.
  • jayc250x
Posted 08 February 2012 - 10:23 PM
I do the same with an X-acto knife. Most metal handguards are thinner than the bar diameter, so falls can jam dirt underneath the throttle tube. I put a fender washer that is slightly larger than the throttle tube OD between the barkbuster and the bar, then set the throttle tube end about 1/16" from the washer. The washer serves to block dirt when you stuff the bar into the ground. Handguards with plastic wraps are usually big enough at the end that you don't need a washer.
JayC
  • Jakeblues
Posted 09 February 2012 - 04:42 AM
JayC
Great idea with the washer!
  • jtucker1974
Posted 09 February 2012 - 07:41 AM
I used a uni bit drill bit for mine. It's a cone shaped bit that steps up in size from 1/4-1 1/4. Works great for enlarging holes because it stays centered. Just drilled it out until it was the same size as the rest of the tube. Didn't lose any length.
  • Jakeblues
Posted 09 February 2012 - 08:19 AM
Sounds good.
  • Sampleinajar
Posted 09 February 2012 - 10:58 AM
Nice idea with the uni bit! Have one sitting there and never thought to use it! (doh!)
