When idling a very fast turn on the throttle kills the engine, if i roll on a little i can rev it up quick and no problems, but even a small instant change in throttle from idle kills it even when the bike is warm
is this normal? or maybe a jetting issue?
3x3 and yosh rs2 at sea level with 145 main and clip on needle in 4th position, stock pilot jet, fuel screw maybe 3 turns out
it idles good and runs good otherwise
please halp
thanks
Quick turn on throttle and Z dies-jetting problem?
Started by
SupermotoByron
, Feb 03 2012 09:49 AM
5 replies to this topic
Posted 03 February 2012 - 11:09 AM
what kind of carb ?
Edited by JEB1962, 03 February 2012 - 11:12 AM.
Posted 03 February 2012 - 11:34 AM
Is your idle set high enough? I had to bump mine up once to eliminate that.
Posted 03 February 2012 - 07:20 PM
stock carb, jd jet kit
general performance is great, idle seems pretty good might be a little slow though ill check that first
Posted 03 February 2012 - 07:28 PM
If you have a tach set to 1700/1800 rpm...It's not uncommon to have a some hesitation from low rpm...
I wouldn't be concerned about it's static performance as its all good when when riding..
