Is this an oem piston?
20 replies to this topic
  • volitan
Posted February 03, 2012 - 06:30 AM
Is this piston an oem for a 2003 yz450?
http://m1131.photobu...ml?o=1&newest=1
http://m1131.photobu...ml?o=2&newest=1
http://m1131.photobu...ml?o=0&newest=1
Any help would be greatly appreciated
Posted February 03, 2012 - 08:10 AM
Maybe.
  • volitan
Posted February 03, 2012 - 08:44 AM
What makes you say maybe?
I've never seen oem or aftermarket ones
Posted February 03, 2012 - 09:16 AM
The fact that I can't tell from those pictures whether it is or is not, but it could be. So, "maybe".
  • volitan
Posted February 03, 2012 - 09:27 AM
Ok
How can you tell if it is or not oem? Is there markings on wiseco or other aftermarkets ones or is there anyway of
Telling if it is an after market or not?
Do you need more
Pictures? What part of the piston i can take a pic of would make you be able to tell if it's oem or not?
Posted February 03, 2012 - 01:41 PM
Why is it important?
  • Yamaryder29
Posted February 03, 2012 - 06:26 PM
What do the pin circlips look like? Usually the stock ones are more traditional looking circlips. Most of the aftermarket ones I've seen are like a ring. IMO, it looks like stock.
  • volitan
Posted February 03, 2012 - 07:33 PM
It is important because I'm changing the rings and not the piston. So I want to make sure
I order the right ones.
The circlip is traditional looking;)
  • 94cr rider
Posted February 03, 2012 - 07:39 PM
looks stock
  • umu24013
Posted February 04, 2012 - 01:01 AM
it is a stock '03 piston
  • volitan
Posted February 04, 2012 - 06:07 AM
Thanks alot guy!
Posted February 04, 2012 - 08:03 AM
It would have helped to know that to start with. Any piston for the bike using the standard 3 ring setup will use OEM rings. The characters "5TA" or "5TJ" will likely be present somewhere on the underside of a stocker.
  • umu24013
Posted February 04, 2012 - 10:00 AM
5TA
5TJ
  • crf450319
Posted February 04, 2012 - 11:50 AM
Get used to having to explain yourself if you want any help here, there are some big ego's floating around that aren't willing to help out unless they're satisfied with "why" you need the info you're asking for. You'll catch the odd good guy like UMU24013, who will offer the info he has on his own..
  • mud_mania121
Posted February 04, 2012 - 12:01 PM
+1 when i read this thread..
  • 94cr rider
Posted February 04, 2012 - 01:26 PM
wen u do rings your supossed to replace the piston, rings,rist pin ,rist pin bearing , timeing chain
  • volitan
Posted February 04, 2012 - 02:31 PM
As long as I get an answer I'm happy:).. But in a
Respectfull way.
Thank very much again. I guess next time I will make
Sure to say why I need to know some thing.. Even though it doesnt matter why I need to know it:).
94cr rider, you don't need to change everything in one shot... In my case I busted the clutch with a rock so I split the engine to make sure no metal went in ad I put new rings while I was at it.
  • 94cr rider
Posted February 04, 2012 - 03:00 PM
ah
Posted February 04, 2012 - 04:01 PM
If you want an accurate answer, you need to ask the question you actually want answered. The OP didn't do that. He wanted to know what rings to buy, but instead posted 3 low quality pics of a piston and asked if it was stock. I could have pulled the answer out of an orifice, but since I couldn't tell definitively from the evidence offered, I decided to find out why he wanted to know, which eventually did in fact lead to his real question being answered.
But it's nice of you to come around and try to start something.
  • crf450319
Posted February 05, 2012 - 05:54 AM
I'm not trying to start anything, just trying to save the OP some frustration. There's an obvious condescending tone here in the yz450f forum, & a pattern of behaviour I've noticed since I've been riding a Yamaha. Exactly the place where people looking for answers shouldn't find that sort of 'tude.
Whatever.... like I said, just trying to save someone some frustration.
Motocross
  • Hot  491 replies
  • 9 replies
  • On Yesterday, 06:20 PM
