I have been searching and reading threads for hours now and I can't see anymore and there is so much to take in I am not sure where to start. Please forgive me for the redundancy.
Ok so my 02 CRF450r seems to be running pretty good but I am wondering if I can get a little better bottom end response/more power through doing more carb mods if there are any I can do. It does still bog if I whip it WOT from idle in nuetral when at heat but seems decent out of corners the last time out to the MX track.
It is an 05 carb that is stock except for the TM bilet mixture screw, bowl drain, and hot start nut. The diaphram is the much smaller rivet type and the AP link lever does follow the Ap set screw so I don't think the Redbeard mod applies.
The induction is stock 02 boot, box, and screen with a uni filter. I have put the 04 flywheel in with entire 05 electrics except for the kill switch which is a new 02. I have a FMF powerbomb header and FMF titanium muffler. Everything else is stock.
Should I go with the Merge APS spring and adjust the timing of the squirt? Modify the induction to a newer boot/subframe/airbox with cut-out and no screen with a No-Toil (sounds expensive)? Jettng kit? Power bowl 2?
I am open to any and all suggestions. I just don't won't to get into engine mods. Don't need the power THAT bad lol.
02 CRF450r
05 Carb w/TM billet mixture screw, bowl drain, and hot start nut
Pilot #45
Main #172
Leak #55
Needle 4th
Elevation sea to 1300' temp 50-75 current. 75-100 summer
FMF Powerbomb w/FMF Titanium Muffler
04 Flywheel w/05 electrics CDI/Stator/Coil/Harness etc
Thank you all!!
