Finally got a 450
2 replies to this topic
  • rhinoracin
Posted January 31, 2012 - 10:56 PM
Picked up this 09 with only 5 hours on it
I have a few questions:
- I replaced the stock air filter with a Uni, and the filter screw was very hard to get into the threads, I basically had to force it in, is this normal?
- What should I set the shock sag to?
- Where can I find white/black/red graphics for just the rear fender?
  • Yamaryder29
Posted February 01, 2012 - 05:22 AM
The air filter bolt should go in pretty easy. Did you have the filter aligned properly? There's a small dowel that on the back of the cage that lines up with the air box.
Set your sag to 100mm. Look on eBay for graphics.
Edited by Yamaryder29, February 01, 2012 - 11:00 AM.
Posted February 01, 2012 - 10:08 AM
Some replacement filter elements can be difficult to install the first several times because the sealing flanges and the dome at the bolt hole are considerably thicker. This often makes it necessary to push inward quite firmly to engage the bolt with the threads while trying at the same time to rotate the bolt and avoid cross threading all at once. Can be kind of a pain. Be sure that the cage is all the way down into the corner crease where the sealing flange meets the dome of the element, and that everything is lined up.
The bike will corner better with the sag set closer to 95mm. If you weigh more than 190 or less than 170 without gear, you should check the free sag against the loaded sag to see if the spring is OK:
http://www.tootechra...ension_tips.htm
http://www.tootechra...pension Tip.htm
  • Hot  36 replies
  • On January 15, 2017
  • Hot  50 replies
  • 9 replies
  • Hot  113 replies
