Edited by scotty2fast, 31 January 2012 - 07:38 PM.
87 quadzilla
Started by
scotty2fast
, Jan 31 2012 07:37 PM
3 replies to this topic
Posted 31 January 2012 - 07:37 PM
Hey Guys , posted this over on the Suzuki 2stroke foum as well, but my neighbor recently purchased a 1987 Quadzilla and the bike will only idle with the choke on , I'm thinking crank seals and maybe impellar shaft and seals as well , when he drained his gearbox it was milky looking and she smokes pretty heavy even after being warmed up. Carb has been gone through and top end has great compression judging by how hard it is to kick . He hasnt thrown a compression tester on it that I know of, so I cant quote any numbers . Also bike has been sitting several years before he purchased it . The P/O was real tool . Any Thoughts ?
Posted 01 February 2012 - 08:09 PM
The old suzuki 2 stroke quads did have water pump seals go bad regularly. I would def get in there and replace those as well as the crank seals. Also check for leaks around the base gasket, reeds, carb etc. Quadzillas are awesome when they are fine tuned! HOLD ON!!!
Posted 07 February 2012 - 08:42 PM
Like mentioned check out the crank seals and impeller seals for the water leak. You also want to take off the magnito cover and check for main bearing play. Try to move the flywheel up and down. It should not have much of any movement. If it moves, then you need to split the cases and have new main bearings installed (along with inserts).
The pilot circuit in the carb is probably all gum'ed up from the fuel sitting in the carb for years. You will need to remove the carb and fully dissemble, clean, and flush out all passages. The pilot circuit/jet is probably really bad. Make sure to drain the fuel out of the gas tank if it is still old fuel. The modern gas with Ethanol is horrible about attacting water.
There are a lot of modifications to the stock zilla (read as factory fixes) to make them dependable and powerful. Head on over to quadracerhq.com and go into the forum there. This site is specific to the LT250 and LT500 quads.
Good Luck,
Larry
Good Luck,
Larry
Suzuki LT185 (1985) |
Suzuki
2003 Suzuki King quad problems....ATV/UTV → Make/Model Specific → Utility ATV |
Suzuki
Ltz400 Dyno 64.33hp/41.57tq!ATV/UTV → Make/Model Specific → Sport ATV |
Suzuki
Yamaha Blaster injector failed. advice?ATV/UTV → Make/Model Specific → Sport ATV |
Suzuki
vinson 500ATV/UTV → Make/Model Specific → Utility ATV |
