I bought a FMF POWERCORE 4 SLIP ON EXHAUST for my 2003 CRF 450R and ever since I installed it the bike will NOT START. What can the problem be ??? It is still quite cold out but still can someone help me out Im no mechanic.
2003 HONDA CRF 450R WONT START
Started by MrElectrician, Jan 31 2012 05:30 PM
8 replies to this topic
Posted 31 January 2012 - 05:30 PM
Posted 31 January 2012 - 08:00 PM
How old is the gas sitting in your carb bowl? On my 04 CRF450R, if the gas was more than two weeks old, it wouldn't start unless I drained the bowl and refilled it with fresh gas. Or, you're not jetted for the cold and the slip on made your off jetting worse.
Posted 31 January 2012 - 09:36 PM
Put your stock pipe back on and see if it will start. I think yoy have something different than the pipe.
Posted 01 February 2012 - 04:39 PM
http://www.youtube.com/chrisbeballin
Posted 01 February 2012 - 06:04 PM
2 years old? Drain the tank. Drain the carb. Fake off the carb and clean it. You need to be able to see daylight through the jets longways. If you don't change the gas your never gonna get it to run right until you do.
Posted 01 February 2012 - 06:48 PM
MrElectrician, on 01 February 2012 - 04:39 PM, said:
The gas is like 2 years old, but I got it to start after a while because I kept kicking ad kicking. Finally got her to go. Check the vid
sounds normal , you got lucky letting it sit so long , you should put in fresh gas
