husqvarna sm510r starting issues
3 replies to this topic
  • g3tag
Posted 31 January 2012 - 12:01 PM
hi. having issues with starting. everytime i try to start it it will just backfire. takes about 20 attempts to start then it will run fine. anybody shed any light on this? thanks
  • OlderHuskyRider
Posted 31 January 2012 - 03:58 PM
Check your rubber intake manifold boot, you could have a real big intake air leak
  • varesecrazy
Posted 01 February 2012 - 05:48 AM
hi ,
an inlet leak is a good possibility - easy to test,
probably worth checking your valve clearances too,
what year SMR..??,
Charlie
  • jyrider
Posted 29 February 2012 - 07:37 AM
+1 on the Throttle body boot worm clamp. I had a similar issue after a viscious backfire. Also, could your TPS setting be way off?
