2010 yz450f linkage kit
3 replies to this topic
  • ColoradoKXer
Posted January 31, 2012 - 10:32 AM
Has anybody bought one of thes linkage kits that go on the back shock? Does it make a difference?
  • jaydavis226
Posted February 07, 2012 - 12:36 AM
I bought SDI linkage, made the bike ride completely diff, for the better. I just bought some new bars, cant wait to try them out on Thursday
  • Stu2
Posted February 07, 2012 - 12:41 AM
Yup i'm running the pro circuit linkage, it helped the bike in terms of stability, I race off road and it helped
I cannot say it will help with mx/sx, I think the reason the bike stands high at the rear with the stock linkage is to help it turn, but this only works if you have a rut or a berm, on flat hard pack corners not so much,
You will have to raise your forks through the triple clamps a fair amount to compensate for the lower rear, or else it wont turn well, I run mine up 8mm and it turns great
  • YamaLink
Posted February 07, 2012 - 07:10 AM
Depending on the length/leverage ratio of the aftermarket link you may need a heavier spring if you are on the border of needing one with the stock setup.
  • Hot  47 replies
  • Hot  50 replies
  • 10 replies
