quiet exhaust
6 replies to this topic
  • uw153
Posted October 06, 2003 - 06:22 AM
All right folks here it goes. Out of all the pipes you guys/gals have tried on the 600R and 650L which one gave you the best results for the lowest db? I tried the search but didn't find anything with this exact question. :)
  • uw153
Posted October 07, 2003 - 06:04 AM
Ah come on now, I try my best to help everyone else out that I can. Some one has to have tried different pipes for sound and power.
  • Rover31
Posted October 07, 2003 - 07:24 AM
Here are my small thoughts
I had the stock exh. then went to the BD baffle for the stocker exh. good improvment still very quiet, next I have put on the FMF full system (purchased from a TT member!), power bomb header and Q pipe another good improvment in power(not a lot but a little)and it is a system that is not to loud.
From my experence it is worth it. You lose weight and gain horsepower. Keep in mind the L is not ever going to be a fire breather without a Lot of Money.
My next mod is a carb (I have a 41FCR to put on, I hear the Edlebrocks are maybe better)then I will do the cam.
So hopefully by next summer, I will be able to tell more.
Oh another good thing to first get is a fork brace. Spend money on your susp and you be surprised at how much faster you can ride. You eleminate a lot of work you have to do to keep the bike going where you want it to go. This translates to longer rides and more fun.
Travis
  • BoZerk
Posted October 07, 2003 - 07:51 AM
I'm worried about getting dinged for not passing the decible test out here in california. I run the honda HRC exhuast tip. It's pretty loud but I don't think it's that bad. I'm gonna start running in some dual sport rides though and I don't want to get turned away because my bike is too loud.
I saw that baja designs has a baffle that I think just goes in the end and attaches with a set screw. Has anybody tried those? Do you have to re-jet? Do they restrict flow or just make it quiter?
  • newmanr19
Posted October 07, 2003 - 12:28 PM
When I bought my 99 L, it had a FMF PowerCore IV.2 pipe on it; it's kind of funny, but when I was trying to find the guy's house that I bought it from; I was having trouble locating it, but then I heard him start the bike up; in his back yard; several houses down from where I was.. needless to say; that pipe was way too loud for my tastes. I put the stock muff back on right away. I do have the Thumper Racing baffle on order so am going to try that out next.
Also, I would agree with someone else who said with large dual-sport bikes, get the suspension taken care of first. There is way more ROI (return of investment) in suspension tuning then in spending tons of money trying to gain a few HP or loose a couple of pounds.
  • jws
Posted October 07, 2003 - 03:32 PM
i am running the baja designs quiet baffle - it slides right into the hrc tip. it really quiets the bike down i do not think its as responsive as running just the hrc tip but it gets you way under the 96db law in california. i was running a 175 main with just the hrc with the baffle iam running a 172 main. that is what bd recommended and it seems to be fine where i ride :)
on the street i perfer a 110db (just trying to stay alive) :excuseme:but in the dirt iam all about stealth mode :D
jeff :D
  • secretatlas
Posted October 08, 2003 - 04:26 PM
don't replace your tip with another tip. the hrc baffle is fine. i have one on my bike and have been tested on several occasions by various rangers/race workers. it blows between 94 to 98 depending on the test.
as long as all the packing hasen't blown out of your pipe you should be fine.
