1. The right exhaust valve bent and kissed my piston.. before i jump the gun and remove the motor to tear my bottom end apart i was wondering if you guys can give me some insight if my piston appears ok from the looks of it.. the vortex piston was installed at the end of august and has maybe 12-14 hours on it at most. in this pic you can kind of see how bent the valve is
here you can see where the valve kissed the piston.. am i ok? am i safe or do i need to clean the top up or worse, change the piston?
2. How can i confirm that the "pro circuit" springs are titanium from the head that i am changing? and if they are titanium and are in good shape... should i run those on my stock head with my stock valves or should i just leave it as is and install my stock head?
i'm sure i will have more questions tomorrow but i want to get these 2 questions out of the way first so i can get everything sorted out and make sure that this job goes as planned.. so what do you guys think?
Follow us:
