I need help identifying source of vibration from our 11.
Its got a high frequency vibration which is enough to shake various frame and sub frame bolts loose.
So far I’ve swapped the crank and mains twice. First time with Hotrods products, thinking I might have got a out of balance crank or bad bearing, and the 2nd time OEM. To no avail.
I’ve just ordered both balancer shaft bearings, and the clutch bearing and sleeve.
What else could I be missing?
Thanks in advance for any suggestions
