so i just made a great soundin muffler usin the can of the gutted stock one and then a core i made at my dads machine shop. the bike seems to like it.
im gettin some ideas.
Started by The_Mx_Junkie, Jan 28 2012 07:52 PM
4 replies to this topic
Posted 28 January 2012 - 07:52 PM
Posted 30 January 2012 - 08:08 AM
Well, to most of the people on this forum, your post is incomprehensible gibberish - I've read it three times and I still don't understand all of it.
Please tell me English is your second language?
As far as lightening the flywheel goes, you can use a lathe, just be sure to avoid cutting any balancing weights that may be on it, just leave the whole section alone. A friend of mine who is a machinist took well over an ounce off another Yamaha flywheel for me. He said the material doesn't cut very cleanly, so you should probably hand this off to an experienced machinist to ensure your part remains functional and stable at 1,000 or more RPM above the TT-Rs maximum engine speed.
For the carb, there's lots of options which have been thoroughly discussed here. I'd suggest completely cleaning the one you have first.
Good luck.
Good luck.
Posted 31 January 2012 - 11:48 AM
i was really tired when i posted that. haha. i was basically askin if theres carbs out there with accelerator pumps that would be the right size for a ttr. i did a search and got nothing.
an inner rotor kit from what i know, is a flywheel that has the stator on the outside of the wheel instead of going in it like the ttr does. a lot of the inner rotor kits have flywheels that are like 2 inch diameter from what ive seen. i did a search on that too and found nothing.
