I was chasing a jetting bog and believe it may rather be an electrical problem. Does anyone have specs on the coil, CDI, and stator; specifically resistance?
1996 250WXC Electrical Specs
Started by placelast, Jan 28 2012 06:55 PM
4 replies to this topic
Posted 28 January 2012 - 06:55 PM
Posted 02 February 2012 - 05:07 AM
Hi ,
do you know what ignition system you've got , as I can cross-reference for you,
I've got the 125 , and left kicker manuals - just nothing covering the 250's direct.,
Posted 02 February 2012 - 05:01 PM
No, though the part # is 8A00 75347, and it is the same up through at least the current model. The 360 has a different model, and I would think the 125 is different as well.
Posted 01 March 2012 - 05:11 AM
I'm pretty sure that they all run the same stator. The part numbers are different due to the colours of the cables & the lugs on the cable ends.
I have a 1996 WR125 & a 2000 WR360 & their stator resistance's is almost the same but with different colours & lugs on the cables. They are physically interchangeable
1996 WR125
STATOR - PART # 800067029
LIGHTING COIL - YELLOW WIRE TO EARTH / 0.6 OHM
PULSE COIL - LIGHT BLUE TO BLACK/WHITE WIRE / 129.5 OHM
2000 WR360
STATOR -PART# 8000 75344
PULSE COIL - LIGHT BLUE TO DARK BLUE WIRE / 127.5 OHM
Ignition coil Im not sure of.
