So first I need to say thanks to the DR pioneers, mx_rob , Head Trama. wildwestsydney, and msiddalingaiah.
I would never have had the guts to start this project, or maybe even think of it if not for their efforts to not only do it, but also post about here for all of us to learn from. As you will see, I borrowed heavily from their work. My goal was to find the simplest path to fuel only EFI operation and maybe add spark latter. And also to minimize the down time, and most of all to not mess up my bike. The bike is running OK now but I still have a long way to go on tuning and several minor issues to solve.
I started with a 2008 DR-650 with some mild upgrades. Opened air box, DJ jet kit, tuned with an installed wideband O2 sensor and AFR gauge, GSXR exhaust, and a JE piston. Basically it ran great, had lots of power, got great gas milage, was still stone reliable and needed nothing. So of course I had to screw with it!
This will be a somewhat long and involved post so I plan to do it in installments. So I guess the logical place to start is the fuel system. TB (Throttle Body), Injector, fuel pump, fuel pressure regulator, and plumbing.
After reading (and re-reading) Rob’s epic post, the selection of the TB and other fuel components was a no brainer. I shameless copied Rob’s work and sourced a LTR-450 quad TB, pump, fuel pressure regulator from ebay. I also followed his lead and picked up a complete wiring harness for the LTR-450 quad that not only gave me all the connectors but also included relays, Inlet Air Temp sensor, and MAP (Manifold Air Pressure) sensor. But I didn't get the CLT sensor.
The TB is 42 mm and came with the injector and TPS (Throttle Position Sensor). I earned from Rob’s post that the injector is rated for 24 Lb/HR and is more than adequate for the DR-650. The TB is a little shorter, a little larger at the intake manifold side and a little smaller at the back than the stock carb. So again following Rob’s lead, I chucked it up in my ancient lathe and turned down the front to fit the stock DR manifold, and made a spacer for the back to match the carb dimensions for both length and diameters front and back.
Here are some pictures:
Turning back spacer in the lathe:
Finished TB with rear adapter in place:
I didn’t have the nifty tab on the frame that Rob’s bike has (mine is a non-California type) and that he used to mount the fuel pump, so I had to make a clamp style mounting bracket from 1/4” aluminum. Ugly but it seems to work.
Here is a picture of the mounted fuel pump.
The fuel return line from the pressure regulator was a bit of a problem. I didn’t want to drill holes in the stock steel tank and also I wanted to avoid using a “T” back into the primary fuel line for fear of having the fuel get hot as some others have experienced. So I have been thinking about a Clarke tank for some time to save weight and gain a little more fuel capacity, and now I had a good excuse. I like the Clarke best mainly because I think it looks better but the IMS may have been a better choice as I believe it comes with two petcocks and would not require any additional holes. I did drill a hole in the bottom side of the Clarke but up high directly below the filler cap, and installed a 3/8” brass fixture. I sealed it up with plastic compatible epoxy. So far no leaks but time will tell. The bottom side of the fixture has a 90 degree elbow to a barbed fitting for the fuel return hose. These are available at any hardware store.
Here is a picture looking into the tank filler with the cap removed.
Here is a picture from the bottom of the tank showing the barbed fitting.
One of the key factors for me was being able to remove the tank to adjust valves and such without having to drain it. With this rig I can still do that as long as the tank isn’t too full.
High pressure fuel is nothing to mess around with so I wanted to stay with Suzuki factory fuel lines if at all possible. Ebay to the rescue!
The fuel pressure regulator is not really mounted yet and just hangs from the three stiff hoses up under the TB. (again like Rob’s) But it can’t really go anywhere or bang into anything. You can see it in this picture behing the wideband O2 sensor, just kind of hanging there.
Well that is about it for the fuel stuff. Much more to follow.
John
