Hey guys...Here I am once again asking for help.....But your so nice!
Anyway..I need some basic advice that hopefully you can give me real quick....As you know I've been redoing my 07 crf450r and have put in a 13.5 high compression piston, hotcams stage two cam and stock head. My question is what would be a good starting point for my jets in my carb? Does the high compression piston affect my pilot or main size? Does the cam? I have 100ll gas and I know that will lean it out a little, but feel the cheap price of it and it's convenience (right next door) make it worthwhile to run, I also know the lead has to help valve life. When I started it, it was hard to start and wouldn't idle without the choke on and the throttle stop screw in to about 3500 rpms..which I know is way too high, and it would rev up and down a little and crackle and pop. Pulled the plug, it was grey, so it's lean, and then took the carb apart to clean out the carb and noticed the needle had a red top which I am sure is a jd jetting needle, which is I think the high altitude one...I live at about 700ft above sea lvl so....I ordered a stock needle and some jets both up and down for both pilot and main. Hoping the needle made the huge difference, and with the stock one it will be much better. Bike had a big bore kit previously, so the jets are 42 pilot which I know is stock and 190 main which is prolly too big (178 stock). So...where should I start? Got a week or so till jets show up.....will let you know how it goes...Thanks in advance guys you are awesome.
