Help...no spark 2005 110
4 replies to this topic
  • drzjeff
Posted 26 January 2012 - 01:52 PM
My father gave me a 2005 klx 110 that has been sitting for a couple of years. Short story long it doesnt appear to have any spark when kicked. the spark plug looks, what should i look for?
  • JJRace
Posted 26 January 2012 - 09:11 PM
turn the switch to run, hold the plug against the head and kick it. is there spark or not?
  • drzjeff
Posted 27 January 2012 - 09:01 AM
No, there is not a spark
  • Swaney93
Posted 07 February 2012 - 06:58 PM
Pull your neutral switch out from under your shift lever. Clean it up until you see the brass contact points on it. Worked for me, maybe it will work for you.
  • Mxdad567
Posted 27 March 2012 - 05:04 PM
you can also disconnect the neutral switch at the plug, Then touch both terminals to each other. If you have spark the neutral switch is bad or the bike has not engaged into neutral. I have that issue now due to the shift star not engaging always.
