how thick is the oil tank cover
3 replies to this topic
  • trevTFD
Posted January 23, 2012 - 07:37 PM
07 yz 450...While changing the oil, i had to force off the oil drain bolt on the starter side of the bike. i had to take the oil drain bolt with vice grips. after finishing i noticed that the bottom cover above the oil drain bolt was worn away. about a M&M size amout was worn away by the vice grips. there is also a crack in side the worn part of the cover. it appears that there is oil leaking from this crack. i am guessing it is leaking for this, or it could be from the copper crush washer. i put the old washer on the new oil drain plug bolt. is the bottom of the oil tank thin enough that i could have put a crack in it?
i put a little jb weld on the crack. after it dries i will put oil back in the bike to see if it holds. has anyone else ever seen this before? thanks
  • 2grimjim
Posted January 23, 2012 - 07:50 PM
At it's thinnest, its about 3mm thick (.120").
  • trevTFD
Posted January 23, 2012 - 07:53 PM
Sorry i am no expert...thats not very thick right? could i have worn through it that easy?
  • 2grimjim
Posted January 23, 2012 - 08:03 PM
It's about 1/8th of an inch. Not very thick.
  • Hot  38 replies
  • 5 replies
  • On January 15, 2017
  • 10 replies
