Drain Bolt coming out durring ride
8 replies to this topic
  • mx4life421
Posted January 22, 2012 - 02:49 PM
While riding last week I noticed my drain bolt (the second one you remove according to the manual). I probly did 5-6 laps with it out, maybe more not sure. Im worried that some dirt got in the motor on top of running my 2011 yz 450f with out oil. Just curious as to what my next move is, I was thinking I'd flush the motor (with out starting it) with some oil. Then just put new oil in it? Also I need the part number or name for that bolt i cant seem to find it. thanks
  • 2grimjim
Posted January 22, 2012 - 03:58 PM
Yeah, I think it would be a good time to pull the valve cover and look for damaged cam journals. They don't survive long without oil. Consider yourself very fortunate if you see no damage. If you lost any oil, there is a good chance there is some damage somewhere.
Don't even consider running your bike again untill you inspect the top end.
Edited by 2grimjim, January 22, 2012 - 04:00 PM.
  • mx4life421
Posted January 22, 2012 - 06:20 PM
Ok well what should I look for? should I drain the oil first?
thanks btw!
Edited by mx4life421, January 22, 2012 - 06:20 PM.
  • BBrown626
Posted January 22, 2012 - 07:17 PM
Drain the remaining oil into a clean container so you can see what you have in there.
If you can drain much oil, you may be OK.
Pull the cams out and look for scoring on the journals or cams. if you have light scoring it can be saved with careful polishing.
  • mx4life421
Posted January 22, 2012 - 08:24 PM
I left my bike in the back of my truck overnight, and the next day there was quite a bit of oil (although mixed with the rain water) in my bed. So im hoping that it came out later than sooner. It is the bolt below the oil filter if that means anything
thanks again
  • mx4life421
Posted February 15, 2012 - 03:42 PM
Any one know the name of the oil drain bolt right below the oil filter? I cant seem to find the part number on the diagram
Posted February 15, 2012 - 04:09 PM
Item number 13 on the Crankcase page: Bolt, Flange, PN 95814-08016-00. You'll also need #14, the copper washer, PN 90201-08087-00
  • mx4life421
Posted February 15, 2012 - 05:01 PM
Thanks alot man!
  • mikedabike
Posted February 15, 2012 - 08:42 PM
Safety wire is your friend.
  • Hot  113 replies
  • Hot  30 replies
  • Hot  47 replies
