check valve clearance
6 replies to this topic
  • chainy
Posted January 22, 2012 - 07:43 AM
I have an 09 kx 250f and it starts fine cold but warm its a bitch, anyway I'm checking the valves for the first time and how much pressure do you use to get the feeler gauge btween the shim and lobe. I have to push pretty hard to get them in and it feels like I'm opening the valve by doing it. I'm very mechanically inclined and it I don't think you shouldn't need that kind of pressure. I would think light pressure in and out. nothing that flexes the feeler gauge, right? Shimming seams pretty simple but it looks like you need the proper reading to get it within spec.
  • antleo
Posted January 22, 2012 - 07:49 AM
you are correct you dont need a lot of pressure.
  • T.RexRacing
Posted January 22, 2012 - 08:09 AM
If you need some pratice on :"feel" use a micrometer and set it to .010". Then wipe the .010" feeler clean and insert it into the mic. That's how I learned and it's served me well for a long time.
  • William1
Posted January 22, 2012 - 08:15 AM
The feeler shold slide in, minimal drag. Not forced nor slip in with no effort. You have to ensure you go straight in and not at an angle as they can confuse you. Be sure the lobe (the 'bump') is pointing AWAY from the vavle stem/bucket 180 degrees.
If you force a feeler in, it will take about the same effort to force an even thicker one in. Once in, feel the drag. Go down in sizes till teh drag barely goes away. That will be the size. Next thinner will feel loose.
  • Limelight
Posted January 22, 2012 - 08:18 AM
T.REX, nice suggestion... I just went in the garage and tried that one. Very clever. I wish I'd thought of it. :smirk:
  • chainy
Posted January 22, 2012 - 09:20 AM
thanks guys, i'll go check them out.
  • still2smokin
Posted January 22, 2012 - 11:53 AM
You could also pick a "go-no-go" feeler gauge set pretty cheaply and any auto parts store.
They are great if you havent used feeler gauges much, they have the size you want at the
tip then .002 thicker about a half inch in.
Racing Okie Style on XR's by Firestone
Dirt Bike   Make / Model Specific   Honda   XR250/400
  • Hot  48 replies
Fouling plugs! NEED HELP! by Enduro488
Dirt Bike   Make / Model Specific   Kawasaki   Kawasaki 2-Stroke
  • Hot  29 replies
What bike is a mechanical nightmare, repairs and maint? by cr-dude3
  • Hot  36 replies
Lets see your vintage ride by ktmoose465
Dirt Bike   Special Interest Forums   Vintage
  • Hot  693 replies
Too rich with Squish mod and Numroe jetting? by LSHD
  • Hot  41 replies
