Replacement Cahin Question
5 replies to this topic
  • chopperman
Posted August 04, 2001 - 06:40 AM
What chain do you guys like to replace the stock peice? This bike will be used in an MX environment.
  • yzf
Posted August 05, 2001 - 05:54 AM
any high quility o-ring
  • IBWFO
Posted August 05, 2001 - 06:19 AM
Unless you are really trying to keep the weight down, I would go with the O-ring.
It will out-last the typical chain 10 to 1.
  • nozzlejockey
Posted August 05, 2001 - 10:48 AM
I replaced the junk stocker with a d.i.d. gold x-ring and have been very happy. I ride about 3 times a week and still use the stock rear spocket. WWW.rockymountainmc.com has the best prices I have found on chains, they beat the other guys by about 20$. good luck.
  • sirthumpalot
Posted August 05, 2001 - 12:45 PM
Did you guys with the o-rings notice any power difference at all between the o-ring and non-o-ring chains?
  • Guest_Guest_*
Posted August 05, 2001 - 01:52 PM
Go with the x-ring, all of the benefits of the o-rings with hardly any drag. I have a year on my DID with no problems!
  • 10 replies
  • Hot  36 replies
  • Hot  50 replies
