So this may sound stupid, but here goes. My friend was telling me that some folks get rid of their clutch alltogether and go with a rekluse with front and rear brake levers on the bars. Sort of like a mountain bike. The reason this topic interests me is because I am a big downhiller getting into mx. Seems like it would work well for me. Any thoughts? I dont mind the clutch and am slowly getting used to the controls. I was just curious on this setup.
REKLUSE CLUTCH QUESTION...
Posted 17 January 2012 - 06:25 PM
Posted 17 January 2012 - 07:34 PM
And some folks do indeed take off their clutch lever & set their bars up with a a left-hand rear brake (LHRB), while keeping the front brake in it's normal spot on the rt. side.
Am I correct in assuming that's what you wanted to do, Brawwwp?
Jimmie
Posted 18 January 2012 - 10:27 PM
Honestly, you can still feather the clutch with a rekluse, so if you owned one, generating drive can still be done the old-fashion way. So for me, I'd keep the clutch lever in tact.
If I owned a 4 stroke, the first thing I'd buy is a rekluse, I think its an amazing product and well worth the price of admission. I think its not worth while in a 2 stroke because they already have very little engine breaking, easy to use clutches (in most cases) and are easy to re-start when stalled.
Posted 19 January 2012 - 08:23 AM
Posted 19 January 2012 - 05:05 PM
Posted 19 January 2012 - 06:41 PM
wes513v, on 19 January 2012 - 05:05 PM, said:
Could not agree more, wes513v! There are a lot of fast riders out there using these things for a reason!
I've ridden a bike with a Rekluse, and wound up really liking it. I had a preconcieved notion that I would not like them, but spending some time with one changed my mind. The Core 2.0 model, or the Core EXP (my friend has the one that has the complete clutch basket from Rekluse; whichever model that one is.... ) works just like a conventional clutch at the lever on starts, "clutching it" situations, & etc.. It has kept him from killing an engine previously prone to flame outs (2007 CRF450) out on the track, and works even better for that in off-road races/trail riding situations.
For the life of me, the only 2 possible situations that I may not like the Rekluse would be Situation #1) Not having compression braking on some hills. On slick, slimy, muddy downhills, I have come to like the compression braking on my Yamaha. And situation #2) may possibly be that you can't bump start the bike with one. On the other hand, the bike ain't as likely to die/flame out with the auto clutch, so that point may well be a wash......
Now, if the original poster is simply wanting to have his dirt bike feel similar in controls to his mountain bike, converting his left side handlebar control to a LHRB could be a good way to go......
Jimmie
Posted 24 January 2012 - 07:10 PM
Really you just forget its there and just use the clutch as normal, but where it shines is where through fatigue you forget to modulate the clutch properly in a corner or stomp too hard on the rear brake where you would normally stall, it saves you !!
Im not gettin any younger and want to enjoy my limited time at the track so it was worth every cent IMO, you still shift, fan and slip the clutch as per normal. The only thing that sometimes is a pain is making sure the free play gain is right in the lever but once you get that sorted its fine.
Posted 02 February 2012 - 10:33 AM
Jimmie
is there any noticible difference between the core exp and exp2.0 feel wise?
Posted 02 February 2012 - 05:49 PM
billbanshee, on 02 February 2012 - 10:33 AM, said:
The only bike I've ridden with a Rekluse is that '07 CRF450.His Rekluse is the Core EXP model. It was somewhere around $800+ in cost. Came with a clutch center hub part, springs, plates, the expanding ring (EXP?) portion of the equation, a clutch cover, and a few other odds & ends. My ridin' buddy said the Core EXP is a little more "durable" for harder riding/racing & such. The $400 EXP 2.0 expanding ring comes with just the ring, and I believe, some springs. You remove several stock friction & drive plates, and the space where those plates were gets taken up byy the expanding ring unit. So the EXP 2.0 actually has less clutch plates in it than stock. Most feel the Core EXP, with the extra plates/ longer center hub/cover to allow more plates is the more durable of the two. But really, the feel and the way both of those clutches work should be pretty much the same.....
The clutch pull on the Honda behaved pretty much normally. My own '06 YZ450F (no Rekluse, yet....) has a pretty light pull at the lever. The Honda's seemed to take a little more muscle to pull in, but not excessively so. I'm certain the Honda's pull already was stiffer than that of my Yammie. You can still fan the clutch lever to get the revs to pick up when, say, coming out of a corner with a jump right after that corner, going up a jump face, or whatever. Works just like a normal clutch. One thing I wish I'd tried was a few practice starts. They're supposed to be really good for that......
Hope this helps some!
Jimmie
Posted 02 February 2012 - 05:56 PM
you still have normal compression braking above idle, the only time it's a problem is if your bike it shut off or your rpm is so low the clutch does not engage
I keep all mine set to tug at idle, which means on downhills I have never had one loose compression braking
Posted 02 February 2012 - 06:23 PM
For you mtn bikers - when you decend gnarly stuff are you more on the rear brake or the front?
Thought so..
Oh yeah, the Rekluse has increased the fun factor as well....
Posted 07 February 2012 - 11:46 PM
Thought so..
Hey, mind sharing your setup? I thought in order to have a LHRB with the ktm hydro clutch, you have to get rid of you clutch lever?
Posted 08 February 2012 - 09:44 AM
Brawwwp, on 17 January 2012 - 06:25 PM, said:
Its nothing like stupid! I set my bikes this way and like it verry much. Makes me a better rider allthoe i´ll never be realy good :-(
Changed the levers on my MTB so i dont get confused. But you need a powerfull bike to start with because you cant use the clutch to rev it up. Then its sheer heaven! You allmost never stall it. The both brakes on the handlebars give you immens control in every situation and you have perfekt feel on slippery uphills whilest little chance of rolling backwarts because you have the rear brake in your hand. Maybe the realy fast riders dont like it but as an everadged rider i´ll go places with it that i´d never see without it.
Posted 14 April 2012 - 12:11 PM
The Rekluse z start also took some getting used to as when in the hills you have to find a dang tree to park your bike against when taking a break because or it will try to roll down the mountain and its also harder to tell when you are in nuetral for backing the bike out of problem since there tends to be a little clutch drag in gear when the bike is running or not.. Also no bump starting. I didn't like these things at first but as I have gotten used to them they seem like less and less of an issue and the fun of riding up the rocks with the Reckluse doing all the modulation work is more than worth it. I have gotten out of shape and going off the trail onto some big boulders where I would have stalled before and the rekluse just let the bike idle down till I was ready to hit the gas again. A great friend to have. I have the shorty lever clutch override lever by the way but don't use it much. I ride at altitude and have the highest rpm engagement spring in which isn't too high at all on mine.
Posted 16 April 2012 - 05:21 PM
Well...
Quote
All three Rekluse Auto-Clutches can be configured to bump-start the engine in the event your normal starting system fails. However, they can not be configured for bump-starting on the go like a standard clutch. One must stop the motorcycle and make an adjustment (on some Rekluse models this requires tools) to bump start and then make another adjustment to continue riding once the engine fires. Bump-starting can be done to get you home.
Also this is a great comparison for anyone wondering what the heck the difference is between the three.
http://www.rekluse.c...rt_faq_cc.shtml
