hi there guys. i just joined, after reading a bunch of great threads i wanted to be part of the fun!
im a 16 year old kid from california and i have just gotten back into bikes. a few years back i had a freakish mishap with my lil' onehundy. wiped out and somehow got my fingers in the rear sprocket on the way down! (&%$#@!)!!! i dont now exacly how it happened, but i was over motorcycles for a while. thankfully i only lost a bit of fingertip on my middle and ring finger, and scar tissue in my pointer finger. but then out of the blue i have regained interest! the bike has been sitting for like three years now and was a pain in my arse to start. i had to push it up my driveway a few times and roll it down with the spark plug out to blow out the gas in the motor. then i had to do that again to get it to start up finally.
the thing wouldnt idle so i took the carb apart and sure enough, the pilot was plugged. so i blasted all the stuff clean. pilot is clean now, and all the circuits of the carb "should " be clean. the two brass tubes on the filter side of the carb are clean, and lead to the pilot and main, and the pilot screw section is all clean.
ok, now the weird part. iv got a manual that states the float hight as 12.5mm, so i set my float at that hight. before the float was wayyyyyy low, and for some reason gas would come out the lower vent/ drain when the bike would shake/ go over bumps. so i raised the hight, and the gas leaking problem went away, even tho the fuel level is now higher.
the bike runs rich on the lower range but bogs out of i snap the throttle open with the motor at idling speeds. i put the choke half way on and it doesnt bog nearly as much.
i ordered some new jets just to see if it helps. (100 main, 38 pilot, recommended for a stock bike right off the bat)
if that doesnt fix it il put the float back to around 20mm like it was in the beginning.
any insight would be great. the bike ran good (but most likely kinda lean from the factory) when it went into storage. of course i forgot to drain the gas out of the bowl tho
also do you guys know if it is possible to repair the fuel tank valve? mine drips a tiny bit when it is turned off. (about 2 or 3 drops per min.)
