400 to 426 conversion, the easy way
48 replies to this topic
  • yz00
Posted April 19, 2012 - 05:54 PM
#41
The 426 piston uses a larger wrist pin, so you'd need the 426 rod
That would allow you to use the 400 crank.
ok so with the 426 cylinder/450 piston and rings you can use the 400 bottom end AND the con rod?
im trying my best to undertsand this all before i make a purchase...
and on top of all that the stock 400 head with decrompres exhast cam..?
Edited by yz00, April 19, 2012 - 06:00 PM.
  • umu24013
Posted April 20, 2012 - 07:05 AM
#42
exactly. 400 bottom end + 400 con rod + 426 jug + 450 (5TJ) piston and rings
yes
  • yz00
Posted April 21, 2012 - 03:18 PM
#43
so will the 426 jug bolt up and use teh same gastkets as the 400 jug?
  • potman1980
Posted April 24, 2012 - 06:43 AM
#44
thanks for your help umu2.
  • umu24013
Posted April 25, 2012 - 09:53 AM
#45
the base gaskets are the same. the cylinder head gaskets are different p/n
Posted April 25, 2012 - 10:00 AM
#46
The difference in the head gasket is the 95mm vs. 92mm bore size. The bolt patterns are the same between the 400 and 426.
  • yz00
Posted May 05, 2012 - 06:58 AM
#47
ok so one more question on this matter. on my 400 turns out the head is bad. my queston, i already have a 450 piston and a 426 jug but now what should i put on for a head? im guessing the 426 is only going to bolt on and would be best choice?
  • shorey400
Posted November 18, 2013 - 12:06 AM
#48
What is the difference with the 2s2 piston? Would this also work?
  • Billy.salmon
Posted July 03, 2016 - 07:55 PM
#49
I'm new here and know this is an old topic but can you use a big bore 450 piston
  • Hot  30 replies
  • 5 replies
  • Hot  36 replies
  • Hot  50 replies
