oil filter
3 replies to this topic
  • nvrlift
Posted August 02, 2001 - 10:45 AM
which way does the oil filter go into the housing....open end out or in?
  • eBayThumper
Posted August 02, 2001 - 12:41 PM
Open end in...
  • sirthumpalot
Posted August 02, 2001 - 01:25 PM
I believe that the open end goes out (facing the plate that you remove). The plate should have a slotted piece of metal sticking out which will fit snugly into the whole in the filter (at least it's this way on my 01' 426).
  • Bill
Posted August 02, 2001 - 02:22 PM
You are correct. The cover has a "tang" that goes into the filter, so the hole is outboard.
99 WR400f, YZ timed, MX-Tech suspension, Scotts steering damper, White Bros E-Series (12 discs), tapered header and a/f. Kouba T-handle for the fuel screw. Works Connection billet throttle tube and frame guards. Cycra Pro-Bend, triple clamp mount handguards. Thumper Racing rad guards, Renthal Jimmy Button highs, YZ Tank and IMS seat, YZ number plate, odo removed, EKP, 48PJ, 175MJ at 500-1000' Thanks James Dean!
  • Hot  36 replies
  • Hot  33 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
