I have an 88 nissan truck with a Z24 engine that blew a head gasket between #3 and #4 cylinder. I had the head shaved, laped the valves in, new gaskets and put her back together. I started her up and it is now not running on #1 and #2 cylinder. Compression is good, I have spark to all cylinders, timing is set right, I cant see any loose connections anywhere, wires or vacuum lines. Anyone know what could be the problem? I was thinking a fuel problem but it is a TBI, it should be feeding all 4 cylinders together, right?
Help with Nissan truck
Started by IHScoutII, Jan 08 2012 01:50 PM
7 replies to this topic
Posted 08 January 2012 - 01:50 PM
Posted 08 January 2012 - 05:20 PM
I wouldn't think it would even start if 2 of the 4 cylinders are not firing. Are you sure that's what is really going on?
Posted 08 January 2012 - 07:08 PM
It may start, but it's going to run like crap, if at all...rattle and shudder worse than a mis-timed Harley with a rigid mounted engine. Probably slam the door for you if you leave it open.
With TBI, it should feed all four cylinders equally. Well, as long as there is nothing blocking the intake ports, such as rags stuffed in there (seen that before).
What is your compression readings per cylinder?
Posted 09 January 2012 - 12:29 AM
It does idle very rough, though seems to smooth out when revved up. This engine has two plugs per cylinder, I can pull all the wires for #1 and 2 and no change in idle, but when I pull the wires for either #3 or 4 it will almost die out. I did not put new plugs in, but I did switch them around to see if that's what was causing the problem and no change. Each plug is sparking when I grounded them to the block. I checked compression on #1, it was about 135, didn't check the others. Is there something that links #1 and 2 cylinders that does not control 3 and 4?
